DVCProHD 720p 23.98 to 1080sf output – General Error (92)
Hi there~
For starters, not sure if this is a Final Cut Error or a Kona error. I am outputting a DVCProHD 720p 23.98 timeline to 1080 psf (23.98). Working in Final Cut 6.0.4, Kona 3, AJA control panel 6.0.2. Mastering to Sony HDWS280.When I go to “Edit to tape” it starts the process – but then before it shuttles the deck it fails with the error: General Error (92).
The in point for the assemble edit is : 00.58.40.00. And the duration of content is 14 mins. approx. The Deck is set up at 23.98psf.
On the Kona Control panel – it show playback at DVCPro HD 23.98, and a 720-1080 convert to 1080sf23.98.
Not sure what is causing this error. Any thoughts?
Thanks, Andrea
