Activity › Forums › AJA Video Systems › DVCPro50/Kona3/FCP6 not playing nicely
  • DVCPro50/Kona3/FCP6 not playing nicely
    Posted by Michael Sacci on June 21, 2007 at 4:16 am
    I had a 10-Bit uncompressed SD timeline that I needed to take offsite to master so I exported a QT with DVCPro50. Brought the new file is and tested it out, it looked horrible, jaggies and pixelated. have to master other files so I took this file with me. That same file on my MBP with Io out to a Digibeta was just fine.
    Seems like DVCPro codecs are not working correctly with FCP6 and the Kona3 card. Anyone else having problems?
    System is 8-core Intel, AJA Kona driver 4.0, OS 10.4.9 File on an external Sata drive. Also tested on my SATA RAID
    Michael Sacci replied 19 years, 3 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    June 21, 2007 at 5:26 am
    What frame size was the dv50 file? 720×480 or 486? You 10 bit timeline is 486, the dv 50 file should have 4 pixels cropped from top and 2 from the bottom to get you to 480.
    Jeremy
  • Michael Sacci
    June 21, 2007 at 6:54 am
    the DV50 is 480 – note the movie file is fine. Mastered just fine with the Io and FCP5.1.4
  • Jeremy Garchow
    June 21, 2007 at 1:25 pm
    Try running the 10 bit movie through an advanced format conversion of compressor instead of Qt export.
  • Steve Covello
    June 21, 2007 at 3:22 pm
    You wouldn’t happen to be looking at it on an HD LCD monitor? they all line-double SD, looks terrible. judge it only on an SD monitor.
    steve covello
  • Michael Sacci
    June 21, 2007 at 9:24 pm
    Jeremy – the file is fine, I’m sure the adv features can make it better but that is not the issue that I’m posting here.
    Steve, I have a SD TV (using the analog component from the Kona 3) and a Apple 23″ LCD (SDI to DVI) so I can set it to actual pixels only. Both look bad.
