Activity Forums Apple Final Cut Pro Legacy DVCPRO50 AJ-SD93 Deck
  • DVCPRO50 AJ-SD93 Deck
    Posted by Little Knoll on January 4, 2007 at 6:59 pm
    I have ‘inherited’ this deck. I do not shoot in DVCPro, but rather Mini DV. I have not had a problem digitizing my footage with the cassette adapter, but I have not been able to master back to Mini DV. I have tried everything. I work with FCP5 on a Mac dual G5. Am I out of luck, or does someone know how I can master back to Mini DV tape?
    Thanks for your input.
    Kimberly
    Rennie Klymyk replied 19 years, 8 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    January 4, 2007 at 7:36 pm
    Must be a switch on it or something to get it to record DV25… it does do it i Know… and the tapes will probablhy play in a sony deck too. Might not play in a consumer camera though. dunno… it only records DVCPRO25 (which is better than miniDV) and 50, but there has to be a switch or something on it to tell it to record that signal.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tom Matthies
    January 4, 2007 at 8:13 pm
    I don’t believe that you can record to a mini DV tape on this deck. Most of the Panasonic DVCPro decks will play back a Mini DV tape with the adapter and after changing the playback settings in the menu but will not record back onto Mini DV tapes. At least that’s the way it works with our old “750’s”.
    tom
  • Little Knoll
    January 4, 2007 at 9:03 pm
    Tom,
    I read the manual and it did not say anything about being able to record to Mini DV tape, but the cassette adapter has the little rec/save button on it so I thought I would throw it out there for someone to confirm before I start mastering to DVCPRO tapes.
    Thanks for you input.
    Kimberly
  • Rennie Klymyk
    January 5, 2007 at 12:25 am
    The AJ-SD93 can record on medium or large DVCPRO cassettes with a maximum record time of 184 minutes (92 minutes in DVCPRO50). It can playback DVCPRO50, DVCPRO, DV and DVCAM tapes, automatically sensing the correct format.
    https://www.panasonic.com/business/provideo/news/news04_036.asp
    Why don’t you sell it and buy a DSR-11 or something that matches your shooting format?
