Activity Forums Apple Final Cut Pro Legacy DVCPRO50 24p still is interlaced
  • DVCPRO50 24p still is interlaced
    Posted by Ryan Wyler on February 22, 2006 at 4:23 pm
    I had an event shoot with Panasonic AJ SDX900P cameras, the footage was shot DVCPRO50 24p. I dumped the footage with a Panasonic AJ-SD93 deck into Final Cut Pro Studio (FCP 5.0.4). I am editing on a 23.98 timebase. When I look at the footage in the track it is interlaced in the following format: 3 progessive looking frames, 2 interlaced frames. I have tried using cinema tools to “reverse telecine” the footage, this makes it look “cleaner”, but it still has one interlaced frame every 4 or 5 frames.
    Any idea where I went wrong? To me it looks like Cinema Tools is picking the wrong A FRAME but I don’t see all the extra options in Cinema Tools that everyone else seems to see in FCP 4. It looks like they hid all the options in FCP5?
    Any help would be great. Thanks.
    Jeremy Garchow replied 20 years, 6 months ago 5 Members · 31 Replies
  • 31 Replies
  • Jan Crittenden livingston
    February 22, 2006 at 6:09 pm
    You say you shot with 24P which would give you a 5 FRAME SEQUENCE AS YOU SAY. Had you shot in 24PA, you could have had FCP extract the 24 frames on the ingest. However in 24P, you will have to tell Cinema Tools which one is the A frame.
    While I am not an expert on this but you should have captured at 29.97 as that is the speed of the recording and capture. Only once you have the material in and have opend Cinema Tools and made the extraction are your files going to be a 23.98. Once you have done this and made new files, these you can import into your sequence.
    Hope this helps,
    Jan
  • Ryan Wyler
    February 22, 2006 at 6:21 pm
    That is my understanding also, the problem is in Cinema Tool there are no options for picking the A FRAME or any settings at all. I posted a screenshot of what I am seeing in Cinema Tools.
    https://bridgetone.com/tmp/cinematools_screenshot.png
    Thanks.
  • Ryan Wyler
    February 22, 2006 at 6:53 pm
    If interested I posted a small clip of the footage here (44mb):
    https://bridgetone.com/tmp/24p/
    If you can, please tell me how to get it to 23.98fps without ANY interlacing.
  • Jeremy Garchow
    February 22, 2006 at 8:05 pm
    What kind of capture hardware do you have?
  • Ryan Wyler
    February 22, 2006 at 8:13 pm
    I captured the footage with a Panasonic AJ-SD93 deck plugged in FIREWIRE directly to my powermac.
  • Jeremy Garchow
    February 22, 2006 at 8:35 pm
    Then how did you digitze 24p?
    Was the footage shot 24p Normal or 24p Advanced?
    Do you have capture hardware? An aja io or Kona2 cards can remove the normal pulldown cadence on the fly with proper setup.
    If this isn’t for a film out and the footage was shot 24pNormal, then it’s fine if you digitize at regular 29.97. It’ll have the filmic look you are going for wihtout having to worry about adding/removing pulldown.
    As Jan stated, if it was shot 24pAdvanced, then you could remove the advanced pulldown on the fly through firewire by tweaking the DV50 preset that came with FCP.
  • Ryan Wyler
    February 22, 2006 at 9:31 pm
    The footage appears to be shot at 24p NORMAL (not advanced). From what you’re telling me I should be editing the 24p footage in a 29.97 timebase. When I do this, I can see clearly two out of five frames are still interlaced. Is this expected?
    I uploaded 10 sequencial frames from the sequence at this location:
    https://bridgetone.com/tmp/24p/frames/
    Thanks.
  • Kevin Hedin
    February 22, 2006 at 9:43 pm
    Picking the A frame can be tricky, but while your in Cinema Tools, picking the A frame is simply choosing the frame that has a progressive frame to the left and to the right. Only the A frame will have a progressive frame immediately to the left and to the right. Park your playhead on that frame, and then do your conform. This should work.
    You can save yourself time with this process if you make sure to capture your footage initially with each clip’s IN point ending in either a 5 or 0. Those two frame’s are A frames, and when you conform footage in Cinema tools using this method, placing the playhead at the head of the clip will always be the A frame. So you don’t have to FIND the A frame with each clip in Cinema Tools. Make sense?
    Since you shot in 24p, not 24pA, this is your only option, however, if you get yourself an IO from AJA or Film card from Aurora Systems, you can remove 24p pulldown on the fly. Personally, I use the AJA IO and it works very well.
  • Jeremy Garchow
    February 22, 2006 at 9:44 pm
    I take it this is your first experince wiht 24p?
    Waht is the intended output? Tape? Film? DVD? Web?
    It was shot normal, as that is a 3:2 pulldown cadence from the looks of the frames you posted.
  • Ryan Wyler
    February 22, 2006 at 9:52 pm
    I tried this method of picking the A FRAME and then selecting the “REV TELECINE”. This resulted in the exact same output.
Page 1 of 4
