Activity Forums Apple Final Cut Pro Legacy DVCPRO HD+Canon7D for Bluray
  • DVCPRO HD+Canon7D for Bluray
    Posted by Andrea Pizzi on July 12, 2010 at 4:55 pm
    hi
    i’ve edited, in final cut pro 6.0.6, a PAL sequence with frame size HD 1440×1080 16/9, Field dominance Upper, Quicktime Video Settings Compressor DVCPRO HD 1080i50
    my material is : some clips from Panasonic 201 (DVCPRO 1080i50) and some clips from Canon 7D (converted in AppleProRes 422 HQ 1920×1080 with MPEG Streamclip)
    since i’m going to create a Bluray disc with Encore CS4
    1 – are my sequence settings in FinalCut correct?
    2 – which is the right/best workflow to reach a fine bluray folder that i will burn with toast…. is CBR 32kbs a good transcoding setting for my case in Encore?
    thanks a lot!
    Ben Hendriks replied 16 years, 2 months ago 3 Members · 5 Replies
  • Michael Sacci
    July 12, 2010 at 7:28 pm
    First, neither of your footage is 1440×1080, that is not a DVCProHD resolution and you should not be using it. DVCProHD is 1280×1080. So your FCP setting is wrong.
    You should not be using ProRes (HQ), for video footage standard ProRes is much better (not so much quality but less issues and HQ will not give you any noticeable quality gains)
  • Andrea Pizzi
    July 12, 2010 at 8:01 pm
    hi Michael,
    ok i’ll set my FCP Sequence frame size to HD 1280×1080 16/9 and pixel aspect HD 1280×1080 and… Quicktime Video Setting ??
    ok for ProRes not HQ.. understood
    then, after rendered the mov with FCP, i’ll import it into Encore and… how do i have to set the transcoding for bluray to get a good quality output?
    thanks again
    Andrea
  • Michael Sacci
    July 12, 2010 at 8:59 pm
    That is an encore question.
  • Andrea Pizzi
    July 13, 2010 at 9:58 am
    anyway… it sounds strange that 1280×1080 you say… i’ve recorded in PAL HD 1080i50 and normally, when i edit that material in FCP it appears to be 1440×1080 anamorphic upper field, so my sequence should be right for pana201 material but, since i’ve included some canon 7D clips (prores and progressive) i’m afraid it’s not a right output setting for the final destination (encore project where i want to use 1440×1080 25fps CBR32)
    Andrea
  • Ben Hendriks
    July 13, 2010 at 12:02 pm
    Hi Andrea,
    1440 x 1080 is correct for DCVProHD 1080i
    Best Ben
