Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD…best output format
Posted by Roberto Lopez on October 22, 2008 at 6:18 pmI just finished a 30min HD short that and want to get the best advice for output to a DVCPRO HD tape and HDCAM that will be my master. Or do I use a D5 as my master. My project is a 720 24pn that was shot with the HVX200 and my sequence setting in FCP is:
FRAME SIZE: 960×720
ASPECT RATIO: HD(960×720) (16:9)
PIXEL ASPECT RATIO: HD (960×720)
EDITING TIMEBASE 23.98
QT VIDEO SETTINGS > COMPRESSOR > DVCPRO HD 720p60my project setup is:
FORMAT: HD
RATE: 23.98 fps
USE: DVCPRO HD-720p24i hear that the Kona 3 is a great to upconvert from 720 to 1080…
Roberto Lopez replied 17 years, 11 months ago 4 Members · 14 Replies -
Walter Biscardi
October 22, 2008 at 6:23 pm[Roberto Lopez] “I just finished a 30min HD short that and want to get the best advice for output to a DVCPRO HD tape and HDCAM that will be my master”
Stay in DVCPro HD to tape and have a post house dub that to HDCAM. We’ve been doing that for four years.
[Roberto Lopez] “i hear that the Kona 3 is a great to upconvert from 720 to 1080…”
This is a cross-convert, not an up-convert. And yes, the Kona 3 does a broadcast quality 720 to 1080 (and vice versa). We’ve been doing that for about three years as well.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Roberto Lopez
October 22, 2008 at 6:34 pmthanks…so either way, still have to go to a posthouse to output to a dvcpro hd tape, this will be my master and a posthouse can dub to hdcam via kona 3 card…regarding sound, my project is in 5.1 (L,C,R,Ls,Rs,Lf) and also in stereo(2mono tracks)…so the post house would be able to make me two dubs, one in stereo and one in 5.1. RL
Walter Biscardi
October 22, 2008 at 6:39 pm[Roberto Lopez] “thanks…so either way, still have to go to a posthouse to output to a dvcpro hd tape, this will be my master and a posthouse can dub to hdcam via kona 3 card”
Then why go to DVCPro HD tape at all? I thought you had the deck.
If you’re going to a post house anyway, just take a self contained quicktime movie with you and have them cross convert your 720 DVCPro HD file to 1080i HDCAM in realtime during layback.
Roberto Lopez
October 22, 2008 at 6:53 pmthanks walter, that’s what i’ll do…i exported my 30 minute timeline with the DVCPRO HD 720p60 codec and it comes out to a 10.25 gig file size…
Chris Borjis
October 22, 2008 at 7:21 pmif you do an HDCAM master (only 4 channels of audio available)
you can have the facility output your stereo mix to ch 1 & 2
and have them encode your surround mix as Dolby-E to ch 3 & 4unless you have them do HDCAM SR in which case there are 12
channels available and no need for Dolby-E to encapsulate your
5.1 mix. -
Roberto Lopez
October 22, 2008 at 8:03 pmfor film festival circuit, would you say HDCAM SR is the way to go or have HDCAM and HDCAM SR for different exhibit format, thanks for everyone’s advice. RL
Chris Borjis
October 22, 2008 at 8:49 pmgood question.
I know that Sony is pressing hard to have HDCAM decks available to
play films for the bigger/prominent festivals now.my guess would be they are equipped with the SR decks which
can also play the regular HDCAM tapes. What I don’t know
is if they have dolby-e decoding in these theatres for the festivals.
not likely since its mostly a “broadcast in surround” option for tv showsSR will definitely cost you more to make a master of.
It’s up to you. Maybe call around and see what they are doing to get
a consensus.Another less costly option with great results is seeing if they will
accept a blu-ray disc. There you get excellent picture quality and
surround sound in an inexpensive medium. A client of mine had me
build a blu-ray of their 720P master (same format you are using) and
it knocked off everyone else’s presentation because all they brought
were DVD’s in SD upconverting through the projector, while the Blu-Ray
blew them all away in picture quality. -
Christopher Wright
October 22, 2008 at 9:37 pmI would be very wary of spending all this extra money to output to an HDCAM tape if you are only submitting to a film festival. VERY, VERY few film festivals have the capability of playing back even Blu-Ray disks, much less having HDCAM decks available for festival playback. Most still only have Betacam and DVD playback capabilities. Definitely check out the exhibiting capabilities of the film festival you have been accepted in before making the HDCAM plunge!
Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
Octocore 8 GB Ram, Radeon card, MBP, MXO
Windows XP Adobe Studio CS3, Vegas 8.0, Lightwave 9.2, Sound Forge 9, Acid Pro 6, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects -
Roberto Lopez
October 22, 2008 at 9:54 pmthanks chris, it’s good to look at all the alternatives, i think blu-ray is good to go for now. RL
