Activity › Forums › AJA Video Systems › DVCPRO HD Wrong Resolution and Pixel Aspect Ratio
Posted by Frederic Lumiere on August 18, 2007 at 4:32 pmI wanted to bring up a pretty major bug that appeared only a few days ago ever since the last update to Pro Apps.
DVCPRO HD 720p & 1080i export self contain movie seems to mess up the native resolution and the pixel aspect ratio therefore forcing a render on a native DVCPRO HD timeline.
We are outputting a 13 part series for the History Channel and all of a sudden our self contained Exports from a perfectly good and rendered timeline require renders.
Our tests show that different duration exports renders different results! Short exports (5 min or so) seem fine, the resolution shows as 960×720 and PAR HD(960×720) but longer ones the resolution in FCP browser shows 1280X720 with Square Pixel Aspect. 1080 resolution has the same issue with 1920 vs 1280.
Although, resetting the resolution in QTPro and the PAR in FCP seems to match other clips that work – a render is still necessary.
I’m assuming the Pro Apps update broke it but I am not sure of course.
This issue exists in FCP 5.x & FCP 6.x
Frederic Lumiere
Frederic Lumiere replied 18 years, 10 months ago 5 Members · 14 Replies -
Jeremy Garchow
August 18, 2007 at 8:51 pmThere’s been some talk of this on the FCP forum. Apparently it’s affecting only some people and not others. I did my own tests today and didn’t have a problem with anything, even 2 hour long timelines, in both FCP 5&6, DVCPro HD (5&6) and ProRes (6).
Jeremy
John Pale
August 19, 2007 at 6:11 amIts not the length of the export that matters.
Some, or even just one, of the clips in your timeline is erroneously being read by Quicktime as having square pixels instead of DVCPRO HD’s anamorphic pixels.
I determined this by gradually exporting sections of my timeline…getting the correct result…until…BAM…I found the one clip that caused the export to go awry.
Add the Broadcast safe filter to that clip, and the export works correctly. It doesnt have to be the Broadcast Safe filter…any filter, even one that changes nothing, will fix the problem, as FCP now reads the render file instead of the original media.
I believe, randomly, Quicktime is messing up in the metadata department and this is causing the issue. I had several timelines which exhibited this problem and there was no pattern to the offending clips. They all appeared normal in their properties (the correct DVCPRO HD pixel aspect and size).
Frederic Lumiere
August 24, 2007 at 12:16 pmI honestly don’t think it’s the case.
Took an hour movie which was rendered a while ago (pre Pro Apps update) in DVCPRO HD 720p60 59.94, dropped it in a timeline – no need to render.
Exported 5 secs of it – no need to rener
Exported whole – needs render
F
Frederic Lumiere
August 24, 2007 at 12:21 pmI honestly don’t think it’s the case.
F
Walter Biscardi
August 24, 2007 at 12:24 pm[John Pale] “Its not the length of the export that matters.
Some, or even just one, of the clips in your timeline is erroneously being read by Quicktime as having square pixels instead of DVCPRO HD’s anamorphic pixels.”
I would agree with this assessment. There is at least one clip in your timeline that is not the same as the rest and it is causing the entire timeline to export in the wrong pixel resolution.
One question I have is why you’re exporting the entire 1 hour timeline as a self contained movie? Are you taking it to another post house to lay off to tape?
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Frederic Lumiere
August 25, 2007 at 3:50 pm[walter biscardi] “I would agree with this assessment. There is at least one clip in your timeline that is not the same as the rest and it is causing the entire timeline to export in the wrong pixel resolution.
Made sense to me but my latest test proves that it isn’t the case. Again, I only have one clip in the timeline and exporting only 5 sec is fine (no need to render when reimporting) where exporting the complete movie (44:50 min) isn’t (needs rendering when reimporting in the same timeline!).
[walter biscardi] One question I have is why you’re exporting the entire 1 hour timeline as a self contained movie? Are you taking it to another post house to lay off to tape?”
I placed only one clip in the timeline just for a test.
John Pale
August 26, 2007 at 1:40 am[Lumiere] “Made sense to me but my latest test proves that it isn’t the case. Again, I only have one clip in the timeline and exporting only 5 sec is fine (no need to render when reimporting) where exporting the complete movie (44:50 min) isn’t (needs rendering when reimporting in the same timeline!).”
I guess this bug is even more random and weird than I thought!
I have not had it re-occur since it happened to me a month or two ago.
In my case, it was definitely not due to the length of the export. Once I took care of the problem clips the long exports went fine.
Keith Koby
August 27, 2007 at 5:56 pmWe’ve been experieincing this problem since upgrading a month or so ago. I originally thought that it only affected media captured with 5.1.4 and imported into 6. I now doubt that, whereas, I believe we have now encountered the problem with media captured in 6.0.1.
I have also encountered a similar problem in nesting timelines. Option clicking a nest to play it back in the viewer has the same strobed playback problem as one of the exported-reimported files described above. Also has the same pixel aspect ratio and frame size errors.
Having said that, I’m thinking it has more to do with FCP than QT.
off topic: we’ve seen the following problem with nests as well as duplicate sequences. see below link. And we saw this problem between ppc and intel long before FCP 6. Could the above and below all be render file related issues?
https://docs.info.apple.com/article.html?artnum=306068
Frederic Lumiere
November 10, 2007 at 8:55 pmThe issue is when non DVCPRO HD clips are included…
There are workarounds (kind of).
Here’s a link to a pdf on the issue:
https://lumieremedia.com/dvcprohdbug/Lumiere_DVCPROHD_BUG.pdf
Frederic
Jeremy Garchow
November 11, 2007 at 4:16 amMan, this is awesome. Did you send this to the Apple feedback page?
Thanks for typing this up.
