Activity › Forums › AJA Video Systems › DVCPRO HD Wrong Resolution and Pixel Aspect Ratio
Frederic Lumiere replied 18 years, 10 months ago 5 Members · 14 Replies
Frederic Lumiere
November 11, 2007 at 1:36 pmYes – Apple has it, they’re working on a fix.
Interestingly enough – after I wrote this I discovered that one of my timeline (seems identical) does not have the issue. Next, I’ll switch clips between timelines and see if the problem is with the clips or the timeline.
F
Frederic Lumiere
November 11, 2007 at 1:55 pmThe problem is with the clip.
Even though they both seem to be perfect self contained dvcpro hd 59.94 movies that do not require render, one generates the bug, the other doesn’t.
I switched clips in timelines and the problem follows the clip – not the timeline.
I will upload 3 sec clips on the link mentioned in the doc and update the doc with this info.
F
Frederic Lumiere
November 11, 2007 at 3:01 pmThe Pdf has been updated with the lastest findings:
https://lumieremedia.com/dvcprohdbug/Lumiere_DVCPROHD_BUG.pdf
It seems that some clips have the issue, others don’t. The Pdf has links to two 3 sec clips one good, one bad.
Now let’s just hope Apple solves it.
F
Frederic Lumiere
November 15, 2007 at 3:59 amIMPORTANT: FINAL CUT PRO VERSION 6.0.2 FIXES THE ISSUE
DESCRIBED IN THIS THREAD
