Activity Forums Panasonic Cameras DVCPro HD route to Avid XpressPro
  • DVCPro HD route to Avid XpressPro
    Posted by Peter Rhodes on January 8, 2007 at 5:39 pm
    I am going to be editing a doc that is shot primarily on DVCam with some scenics shot on DVCPro HD, the show will be edited on Avid XpressPro. The cameraman has delivered several DVD’s with “QT-wrapped” DVCProHD files. He believes it is possible to import these files to Final Cut Pro and export them as DV files that I can import to the Avid. Is this correct? Do I need any extra software? Is there a way to avoid the FCP step and convert the files as they import to the Avid?
    Thanks very much,
    Peter Rhodes
    Boston, MA
    Jeremy Garchow replied 19 years, 8 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    January 8, 2007 at 5:40 pm
    Why can’t he give you the MXF files?
  • Peter Rhodes
    January 8, 2007 at 6:17 pm
    I’ll check to see if he can. Can mxf files import directly in DV format?
    Peter Rhodes
    Boston, MA
  • Jeremy Garchow
    January 8, 2007 at 6:22 pm
    NOt if he shot in HD. I would import the MXF files to Avid and then do your conversion there, rather than take a quicktime file, convert it to another quicktime file, and then convert it to an Avid file. he can also downconvert in camera to give you a dv tape. Wouldn’t that be the easiest?
    Jeremy
