Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO HD Rendering Incorrectly – Loses Sync
  • DVCPRO HD Rendering Incorrectly – Loses Sync
    Posted by Jt on June 5, 2006 at 3:01 pm
    Hi, I’m working with 720 24p HD footage, mostly from P2, and the HVX200.
    Here’s my problem: If something plays with real-time, everything plays well, and looks good. As soon as I render it, the first and last frames of a transition will have a skip in it, as if the render timebase were different; and the interviews that I render end up having the audio out of sync. So, what’s the deal? It was shot as 720p 24N, and I’m using the Sequence Preset DVCPRO HD 720p24… wouldn’t this be correct?
    So, either I’ve got a Sequence Preset set incorrectly, or, FCP 5.1.1 is giving me a hard time. Whatever the case, anyone know the answer?
    Gary Adcock replied 20 years, 4 months ago 2 Members · 1 Reply
  • Gary Adcock
    June 5, 2006 at 7:05 pm
    [JT] “As soon as I render it, the first and last frames of a transition will have a skip in it, as if the render timebase were different;”
    Sounds as if you have overlapping render files
    go to Menu > Tools > Render Manger
    and check the column tom delete all of your render files and re-render. That should fix the issue.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
    gary@studio37.com
