Activity Forums Apple Final Cut Pro Legacy DVCPRO HD Quicktime files, play in FCP but not Quicktime!
  • DVCPRO HD Quicktime files, play in FCP but not Quicktime!
    Posted by Dustinn Craig on April 30, 2007 at 7:20 pm
    I just did a shoot using the Panasonic P2 Cards as capture, and I imported the clips into a G5 powermac, and they translated fine. I then copied the QuickTime files from the capture scratch folder onto a portable HD for travel. These Quicktimes play fine in Final Cut, but will not play back on the desktop as normal QuickTime files. Any clues?
    The QT window will be all white, but the audio can be heard. I wanted to play these files in QuickTime so I can label them for quick reference and scene description.
    Is there a specific plug in I need?
    I have QuickTime 7.1.5 and FCP 5.1, running on a MacBook Pro.
    BetterOnes Productions
    Shane Ross replied 19 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    April 30, 2007 at 7:26 pm
    The DVCPRO HD codec only comes with Final Cut Pro. If you don’t have Final Cut Pro on your laptop, then you can look in the QUICKTIME folder in the Library and see if you can copy over the DVCPRO HD codec.
    Shane
    Littlefrog Post
    http://www.lfhd.net
