Activity › Forums › Panasonic Cameras › DVCPro HD on old G4
DVCPro HD on old G4
Posted by Nick Lammers on June 5, 2008 at 6:29 pmHi. I’m still limping along doing SD on my old G4. Any change it would handle DVCPro HD video in FCP?
Nick Lammers
Media Mill, Inc.
St. Louis, MOMedia 100i XS 8.2.3a on an old G4
Producer 11.5.1 on MacBook Pro 2.33 GHz core 2 DuoShane Ross replied 18 years, 1 month ago 5 Members · 13 Replies -
Nate Stephens
June 5, 2008 at 10:28 pmMy Dual 1gig G4 does DVCpro HD,, just expect longgggggggg renders…
My Macbook Pro 2.4 out performs it,, no contest….
Shane Ross
June 5, 2008 at 11:25 pmI use my Powerbook G4 laptop to edit DVCPRO HD. Works fine. But, as said…LOOOOONG renders.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
John Sutherland
June 6, 2008 at 2:50 amHow are you monitoring the HD picture on your G4?
John
John Sutherland
MDD G4 dual 1.25
1.12 gb ram
Atto UL3D
Huge 1.2TB Dual Max
FCP 4.5
CW 4.7
OSX 10.3.6/QT 6.2.5
Radeon 9000 w/2 17″ crt monitors -
Nick Lammers
June 6, 2008 at 2:56 amHi. Thanks for the input. I haven’t gotten to the point of thinking about monitoring yet. Since the shoot is just an interview I may trying relying on my Apple 23″ cine.
Glad to hear the G4 should handle it. I also have MacBook Pro (2.3) so that might be the way to go.
Nick Lammers
Media Mill, Inc.
Producer 11.5.1 on MacBook Pro 2.33 GHz core 2 Duo -
Shane Ross
June 6, 2008 at 4:46 amI use the Matrox MXO for my Powerbook.
Shane
http://www.LFHD.net
Read my blog! -
John Sutherland
June 6, 2008 at 8:13 pmSo the Powerbook screen is your FCP screen and the Cinema Display is your “program” monitor? Do you use the ACD as both desktop and “monitor”, looking at a larger full rez picture as needed or is it a dedicated HD monitor? Are you working exclusively in HD, and any work flow issues that you’ve had to deal with using this set-up? The MXO seems like a pretty nifty device, and as I do a fair amount of location editing I’m considering going with a MacBook Pro for my next upgrade, so thanks for your input.
John
John Sutherland
MDD G4 dual 1.25
1.12 gb ram
Atto UL3D
Huge 1.2TB Dual Max
FCP 4.5
CW 4.7
OSX 10.3.6/QT 6.2.5
Shane Ross
June 6, 2008 at 9:05 pm[John Sutherland] “Do you use the ACD as both desktop and “monitor”, looking at a larger full rez picture as needed or is it a dedicated HD monitor?”
Both. As a second monitor when editing, and then as a reference monitor when showing cuts to producers and color correcting.
[John Sutherland] “Are you working exclusively in HD, and any work flow issues that you’ve had to deal with using this set-up?”
Yes, exclusively HD. NO…no issues.
Shane
http://www.LFHD.net
Read my blog! -
John Sutherland
June 7, 2008 at 4:17 amHow is the downscaling quality, and what are you using for media drives?
John
Aynsley Baldwin
August 8, 2008 at 9:45 pmI’m about to start cutting DVCPRO HD 1080p30 footage on my 1.67 GHz G4 Powerbook. We did some tests today and FCP was dropping frames all over the place on playback. I do only have 1.5 GB total RAM… you say that extra 500 MB will really help?
Either way, if I turn off the dropped frames warning, I can’t detect the dropped frames. Or at least I couldn’t today in our somewhat rushed tests…
Aynsley Baldwin
August 8, 2008 at 9:52 pmForgive me, why is the MXO needed? Why couldn’t I hardwire an ACD directly out of my 17″ Powerbook?
