Activity Forums Apple Final Cut Pro Legacy DVCpro HD live capture trouble
  • DVCpro HD live capture trouble
    Posted by Remington Swales on January 10, 2012 at 6:12 pm
    Hello All,
    I am gonna be doing live capture from a HDX-900 into my 17″ Macbook Pro (2011, i7, quad-core, 750GB 7200 RPM, 4GB RAM) I’ll be capturing to an external hard drive on set.
    Capturing into Final Cut Pro 7.0.3.
    Capture Preset:DVCPRO HD – 720p60 48 kHz
    Device Control Preset: Non-Controllable Device
    Doing some testing before the shoot and Final Cut will see the camera fine allows me to do a capture now and will let me playback the clip. When I play back the clip there is a 1 second delay with the audio the first time you play the clip. When I switch back to the Log and Capture window it takes about 9 seconds to see the camera again. I can do this about 2-3 times. Upon trying to go back to the Log and capture window a 3rd or 4th time I get the spinning wheel and Final Cut quits.
    Any advice would be greatly appreciated.
    Remington Swales replied 14 years, 8 months ago 2 Members · 2 Replies
  • Bret Williams
    January 11, 2012 at 4:39 am
    What are you using to capture the footage? Are you closing the log and capture window when you switch to playback and vice versa?
  • Remington Swales
    January 12, 2012 at 3:54 am
    I am doing a live capture from a Panasonic HDX-900 via firewire into Final Cut Pro using Log & Capture. I have tried both just changing the active window pane between the L&C window and the browser window for playback and closing the log and capture window after each capture and then reopening. Yet I can only do this 2-3 times before Final Cut crashes while trying to open the Log & Capture window.
