Activity › Forums › Apple Final Cut Pro Legacy › DVCpro HD dubs
DVCpro HD dubs
Posted by Nathan Daniel on April 8, 2008 at 6:23 pmHow do you create exact copies of DVCpro HD tapes without loss of quality and keeping exact timecode? I have heard that you can either use two decks or capture from firewire into final cut and then export back to a new tape. What equipment/software do I need?
I have the latest version of Final Cut and a Quad Core Intel 2.8Ghz Mac.
Thanks for the help.
Sean Oneil replied 18 years, 5 months ago 6 Members · 11 Replies -
Walter Biscardi
April 8, 2008 at 7:06 pmYou just clone them deck to deck. that’s what we do all the time.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Nathan Daniel
April 8, 2008 at 8:22 pmThanks for the quick response.
What decks, cables, etc., do you need?
Walter Biscardi
April 8, 2008 at 8:34 pm[Nathan Daniel] “What decks, cables, etc., do you need?”
We have two Panasonic 1400’s that we tie together via HD-SDI cables for video and just standard BNC for the TC.
You just can’t use the first generation DVCPro HD decks with tapes that have been shot with the newer generation cameras. 1200A and 1400 are the two most popular VTR’s out there.
Read my Blog!
Logan Kelsey
April 8, 2008 at 11:49 pmBe sure that you to get the proper frame-rate flags (UB) on the tapes when you make dubs. I got bit by this. I had some dubs made by a 3rd party, and the tapes didn’t the proper flags and that was a problem for all my off speed stuff, etc… Here is part of a response from Gary Adcock:
https://forums.creativecow.net/readpost/120/857618
HTH
Cheers,
LoganVertical Online
https://www.verticalonline.com -
Sean Oneil
April 9, 2008 at 5:27 amSDI dubbing is lossy on the 1200, the 1400, and the 1800. You need to use Firewire for lossless cloning.
The 1700 model had an SDTI option which allowed lossless dubbing over BNC cable.
Sean
David Roth weiss
April 9, 2008 at 6:14 am[Nathan Daniel] “I have heard that you can either use two decks or capture from firewire into final cut and then export back to a new tape.”
Explain something to me please… Exactly how would you possibly copy/clone a tape without one or the other of the above?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Walter Biscardi
April 9, 2008 at 12:32 pm[Sean ONeil] “SDI dubbing is lossy on the 1200, the 1400, and the 1800. You need to use Firewire for lossless cloning.”
That’s what I thought too until I checked with my Panasonic reps. It’s a clean digital pipe either way. We’ve checked our dubs against scopes and the clone is a perfect digital replica of the original.
Read my Blog!
Gary Adcock
April 9, 2008 at 2:10 pmOne is a dub and one is a clone….
With FW connection the 1200 and 1400 decks have the ability to CLONE the data from tape to tape when coping. (a clone is a digital copy, and since the data being passed back and forth is just the digital 1’s and 0’s)
Using HDSDI is a making a Dub (since the video is passing out over Baseband and then back to tape)
Walter is correct in that the loss of detail in the Dubbed tape should be under a .1 % IRE variance according to Panasonic’s info. (1/10 of 1 percent)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Nathan Daniel
April 9, 2008 at 2:10 pmThanks for all your help. I guess the only clarification that I need now is whether I should hook two 1200As together with firewire or a 1200a to a 1200a or 1700 over BNC. Is the setup process for firewire dubbing much easier then the BNC process?
Sean Oneil
April 9, 2008 at 5:40 pm[Nathan Daniel] “Thanks for all your help. I guess the only clarification that I need now is whether I should hook two 1200As together with firewire or a 1200a to a 1200a or 1700 over BNC. Is the setup process for firewire dubbing much easier then the BNC process?”
Again, firewire is lossless. BNC is not (you need two 1700 decks to do lossless with BNC).
Walter and Gary have pointed out that SDI to SDI with these decks are virtually lossless as far as the scope readouts are concerned. But firewire is a digital data copy, not a dub. So you can’t go wrong with firewire. I’m guessing they’re on the same equipment rack, so there’s no reason to use BNC anyways.
Sean
