Activity Forums Apple Final Cut Pro Legacy DVCPro HD Commercial output to Betacam SP
  • DVCPro HD Commercial output to Betacam SP
    Posted by Claude St-arnaud on October 15, 2009 at 3:19 pm
    Hello Cow People!
    I’ve read in the COW FAQ the answer to the downconvert from HD to SD with FCP using the Kona cards. It made the procedure quite clear to me but still, before sending out a commercial on Beta tape, I’d like to run a few questions by you fine folks.
    Do I use the HD bars generators in FCP timeline or NTSC Bars? Will the Kona 2 convert from Rec 709 to Rec 601 if I leave it to Auto in the YUV to RGB conversion pop-up? And why is my brain leaking from both ears?
    Thank you.
    Claude St-Arnaud
    Editor
    Zeste Production Inc.
    Machine Name: Power Mac G5
    Number Of CPUs: 2
    CPU Speed: 2.3 GHz
    Memory: 2 GB
    Kona 2
    Claude St-arnaud replied 16 years, 10 months ago 3 Members · 4 Replies
  • Shane Ross
    October 15, 2009 at 4:13 pm
    [Claude St-Arnaud] “Do I use the HD bars generators in FCP timeline or NTSC Bars”
    HD bars. This is an HD sequence. You are downconverting the HD sequence, so the colorspace will change. The bars will adjust to the SD space, but they need to match the HD one you are currently in.
    [Claude St-Arnaud] “Will the Kona 2 convert from Rec 709 to Rec 601 if I leave it to Auto in the YUV to RGB conversion pop-up?”
    Got me there. I would think so…
    [Claude St-Arnaud] ” And why is my brain leaking from both ears? “
    Because HD hurts…too much to know. And you can’t know it all. Thus my semi-response to question 2.
    Shane
  • Claude St-arnaud
    October 15, 2009 at 5:35 pm
    Great! Thanks for the help Shane. The colorbars need to be in the standard the sequence originates, and the colorspace will take care of itself. Now I will go and pray to the Kona Gods…
    Claude St-Arnaud – Editor
  • Arnie Schlissel
    October 16, 2009 at 12:07 am
    [Claude St-Arnaud] “And why is my brain leaking from both ears? “
    Either not enough coffee or not enough beer. Possibly both.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Claude St-arnaud
    October 19, 2009 at 1:43 pm
    I will keep try to up my coffee intake, there is lots of room for improvement in that area.
    Thank you Arnie!
    Claude
