Activity Forums Apple Final Cut Pro Legacy DVCPRO HD & AVCHD as a multiclip
  • DVCPRO HD & AVCHD as a multiclip
    Posted by Eric Cosh on September 15, 2007 at 2:44 pm
    Hi all:
    I’m not sure if this thread has been covered in the past. My question is has anyone been successful in making a multiclip (FCP 6) using clips from both an HVX200 (720P 24PN) and video shot using AVCHD ? It looks pretty good just cutting in clips on top of my HVX footage, but I haven’t been successful in making a four camera multiclip (2 HVX200’s & 2 SD-1’s)
    Eric Cosh
    Paradigm Video Productions
    Eric Cosh replied 18 years, 11 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    September 15, 2007 at 5:46 pm
    Transcode the AVCHD materail to DVCPROHD… then create the multiclip from the new file.
    Jerry
  • Eric Cosh
    September 15, 2007 at 8:37 pm
    Hi Jerry:
    Thanks for the very quick response. I just want to be clear on this. Are you saying that I should capture the AVCHD footage directly to DVCPROHD, or that I should capture the AVCHD footage into FCP and then export that footage to DVCPRO?
    Sorry about my confusion on this.
    thanks,
    eric
  • Jerry Hofmann
    September 16, 2007 at 3:13 am
    If you can capture directly to ProRes(have the capture card, Mac and drive space available) that’s optimum.
    Otherwise you need to transcode to it after you transfer it natively.
    Jerry
  • Eric Cosh
    September 17, 2007 at 12:12 am
    Thanks Jerry for your help.
    What I ended up doing was to start off with DVCPRO HD as my sequence settings. I then captured the AVCHD footage, dropped it onto the timeline, rendered it then exported it out QT as DVCPRO HD and then imported it back into my browser.
    When I set in and out points on both clips and made it into a multiclip, it worked great.
    thanks again for your help on this.
    eric
