Activity Forums Apple Final Cut Pro Legacy DVCPRO HD 960×720 confusion
  • DVCPRO HD 960×720 confusion
    Posted by Mustafa Bhagat on October 18, 2008 at 5:22 pm
    Hey all,
    I have been through a bunch of posts and i THINK i got the info i needed but just want to confirm.
    I am loading DVCPROHD 720p60 via firewire into FCP 6.0.4 The pixel aspect ratio says 960×720 after i digitize the clips (i am simply using the DVCPRO HD 720p60 easy setup).
    Is this correct? i thought DVCPRO HD we 1280×720?
    Do i need to edit in a 960×720 sequence or a 1280×720 sequence?
    When i played my footage out to an HD monitor (via the DVI output on my laptop – using cinema display in my playback settings) the image was floating in the middle of the screen. I was just playing individual clips form the viewer.
    I plan on screening via intensity pro HDMI to a dell HD monitor but have not installed that hardware yet. Just digitizing right now.
    Any insight is much apprecieated
    best
    Mustafa
    Russell Lasson replied 17 years, 11 months ago 2 Members · 1 Reply
  • Russell Lasson
    October 18, 2008 at 6:08 pm
    The actual pixel resolution of DVCPROHD is 960×720. So it is actually 4X3. But instead of using square pixels, it uses rectangular pixels, so it stretches the image to reach 1280×720 on playback.
    So your sequence frame size will be set to 960×720 with the pixel aspect ratio set to HD (960×720). This will playback DVCPROHD files.
    [Mustafa Bhagat] “When i played my footage out to an HD monitor (via the DVI output on my laptop – using cinema display in my playback settings) the image was floating in the middle of the screen. I was just playing individual clips form the viewer. “
    Did you have the cinema playback set to RAW or Full screen?
    -Russ
    Russell Lasson
    Ridgeline Digital Cinema Mastering
    Universal Post
    Salt Lake City, UT
