Activity Forums Apple Final Cut Pro Legacy DVCPRO HD 720p50 to tape(DigiBeta)
  • DVCPRO HD 720p50 to tape(DigiBeta)
    Posted by Tino Zidore on September 25, 2008 at 11:23 am
    Hi!
    I am having extreme problems with outputting DVCPRO HD 720p50 material to tape through a AJA KONA 3 downconversion to Digibeta tape(625i25).
    I have had Generel Error 88 once and change the Device control to Sony PAL VTR, which helped, but then I got another problem.
    The was set at 00:01:58:00, but it was out of sync on the tape, for me to get it in sync a had to put on the timeline at 00:01:48:04. Then it would be on 00:01:58:00 on the tape as it should be.
    But why this, it’s a very weird I think?
    /Tino Zidore
    Final Cut 6.0.3
    Quicktime 7.4.5
    KONA 3
    Eric Sternberger replied 17 years, 11 months ago 2 Members · 3 Replies
  • Eric Sternberger
    September 25, 2008 at 12:34 pm
    …are you using a genlock?
  • Tino Zidore
    September 25, 2008 at 2:05 pm
    Yes we are using genlock actually a sigma;-)
    /Tino Zidore
  • Eric Sternberger
    September 26, 2008 at 2:20 pm
    make sure in your aja control panel: timecode burn-in is set to “off”.
    precode your tape with the vtr-controls. then edit to tape. should work fine
