Activity Forums Apple Final Cut Pro Legacy DVCPRO HD 720p to SD AJA 10-bit without a distorted aspect
  • DVCPRO HD 720p to SD AJA 10-bit without a distorted aspect
    Posted by Matt Kerstein on May 1, 2009 at 7:02 pm
    AM I CRAZY OR JUST GOING ABOUT WRONG? IS THERE A WAY TO GET A CENTER CROP LIKE MY AJA DOWN CONVERT DOES THAT WILL GIVE ME A SD VERSION OF SOME HD FOOTAGE THAT IS NOT SQUEEZED OR STRETCHED IN THE FINAL LOOK. DONE MANY TRIES IN COMPRESSOR..ENDED UP JUST RENEDERING IT OUT ON MY FCP TIMELINE. WHAT IS THE CLEANEST WORKFLOW?
    Matt Kerstein replied 17 years, 4 months ago 3 Members · 4 Replies
  • Steve Eisen
    May 1, 2009 at 7:28 pm
    Turn off your Caps!
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Shane Ross
    May 1, 2009 at 7:35 pm
    Depends…is there a way you can undo the caps lock so you aren’t shouting please?
    Thank you.
    IN Compressor, in the INSPECTOR, in the GEOMETRY tab (second from the right), choose CROP TO: 4:3 (1.33:1). That will show you a red box on the image and what will be retained will be inside the red box. This is a standard center crop.
    Try a small sample to see if it does what you want.
    Shane
  • Matt Kerstein
    May 1, 2009 at 8:16 pm
    Sorry just a bad habit as a lazy typist :/
    Aloha & Mahalo from Maui
  • Matt Kerstein
    May 1, 2009 at 8:17 pm
    Thanks..I’ll try that..Caps is just a habit..did not mean to offend anyone..ooops
