Activity Forums Apple Final Cut Pro Legacy DVCPro HD 720p issue in Final Cut Pro 7.0.3
  • DVCPro HD 720p issue in Final Cut Pro 7.0.3
    Posted by Javier Lopez on June 29, 2012 at 3:57 am
    Hello Gentleman,
    I have an issue rendering from 1080i60, when I render to DVCProHD 720p 60 0r 30, it only renders half of the sequence, the total sequence is 6 minutes, and it only renders 2.30 minutes, please I am on the deadline and I can not solve the issue, I greatly appreciate all the responses.
    Thanks in advance!.
    Javier Lopez replied 14 years, 2 months ago 3 Members · 5 Replies
  • Shane Ross
    June 29, 2012 at 4:04 am
    Does it give an error of any sort?
    Shane
    Little Frog Post
  • Javier Lopez
    June 29, 2012 at 5:46 am
    Hello Shane,
    No, I don’t get any error message at all, just partially renders the sequence.
    Thanks for your time and response.
  • Shane Ross
    June 29, 2012 at 6:20 am
    What bar do you have over the areas that need rendering? Is render control set to render that color of render required?
    If so…trash your preferences.
    Shane
    Little Frog Post
  • Tom Matthies
    June 29, 2012 at 1:16 pm
    I’ve had issues where certain filters won’t render in a 10bit ProRes timeline. Is your time ProRes or DVCPro? In either case, try going to your sequence settings and set it to 8-bit rather than 10bit and give it another try. I had the same issue you are seeing a few months ago and that fixed it. It was a Boris effect that didn’t play well on by system at 10-bit.
    E=MC2+/-2db
  • Javier Lopez
    June 29, 2012 at 11:14 pm
    I appreciate the responses,
    I will try both options from Shane and Tom, Shane, before I export I make sure that all the regions are rendered, but still, no luck.
    Thanks in advance.
