Activity Forums Blackmagic Design DVCpro HD 1080p25
  • DVCpro HD 1080p25
    Posted by Jean-yves Le moine on June 16, 2005 at 7:09 pm
    hi
    there is not any settings in the last driver under tiger and fcp 5 for working in 1080p25 with a cam like the panasonic HVX 400 which can record it
    i try the 1080p24 settings with frame at 25 but it didn’t work
    so i try 1080i50 settings and put the priority to none in the settings of the sequence
    is the good way to do?
    what is really the 1080p24 digitiser doing compare to the 1080i50
    jean-yves le moine
    temps r
    Jean-yves Le moine replied 21 years, 3 months ago 2 Members · 3 Replies
  • Luke Maslen
    June 17, 2005 at 1:50 am
    Hi Jean-Yves,
    We deliberately do not include a 1080p 25Hz easy setup although it would be easy to do as the card is programmable. Most people use 1080i/50 with both interlaced and progressive video. There is a 1080p 25Hz standard but it’s incredibly rare and we haven’t had any requests for it. We haven’t included a 1080p easy setup for 25Hz as customers would then use the wrong easy setup in many cases. We could add 1080p 25Hz support in a heart beat if required.
    None of the CRT monitors (with the exception of the Cin
  • Luke Maslen
    June 17, 2005 at 2:07 am
    That should have read, “If you really need to do 1080/25p ….”
    I have added a technical note about this to our web site.
    https://www.blackmagic-design.com/support/detail.asp?techID=107
    Regards,
    Luke Maslen
    Blackmagic Design
  • Jean-yves Le moine
    June 17, 2005 at 3:54 pm
    thanks luke
    in pal country the SONY FW750 is 1080p25 like the hvx 400 from panasonic and the fure HVX 200
    it is the best way in europe to shoot in HD before going to film
    it is very usefull
    thanks for your tips
    what is the 24HZ digitiser?
    jean-yves le moine
    temps r
