Activity Forums Media 100 DVCPRO HD 1080p25 codec seems missing
  • DVCPRO HD 1080p25 codec seems missing
    Posted by John Twigt on August 17, 2009 at 6:16 pm
    Does anybody know if in V14 the 1080p25 codec has been left out? I’m not able to import XML files from FCP in this format. Also the ingested (by FCP) files cannot be played with the QT-player of my M100 startup disk. Everything is fine in FCP startup. Is there a way to ‘make’ the 1080p25 tagged files into 1080i50 format? (in fact they were shot on a Panny HPX500 in 1080i50 format but somehow while ingesting FCP ‘thinks’ they’re 1080p25. I’m confused and somewhat frustrated, in Media100 V12 (and maybe V13, not sure) I could exchange without problems.
    Any suggestions are welcome.
    (using FCP 6.0.6, m100 V14, aja LHE with drivers 6.0.3, mac osx 10.5.7. (m100) 10.5.8 (FCP) PPC 4×2.5 GHZ, QT 7.6.2.)
    John Twigt
    Workstation BV, Amsterdam
    The Netherlands
    http://www.workstation.nl
    Wickham Strub replied 17 years ago 4 Members · 17 Replies
  • 17 Replies
  • Floh Peters
    August 17, 2009 at 6:57 pm
    Do you have the codecs installed? You need the DVCPro codecs from FCP. Since you cannot view the files in QT Player, I guess they are missing. Simply copy them over from your FCP startup drive. Btw, you also can install Media100 and FCP on the same startup drive…
  • Michael Slowe
    August 17, 2009 at 8:53 pm
    Floh, while we’re talking about 1080 x 25P, can we import and edit Progressive in version 14, either on the G5 PPC or the G5 Intel?
    Michael Slowe
  • John Twigt
    August 18, 2009 at 6:54 am
    Hi Floh, I have all the codecs installed, as I said I did do the procedure before when running V12, so I’m baffled now.
    I have the feeling that FCP does interpret the footage wrong while ingesting. The same footage when ingested in M100 isn’t 1080p25 but 1080i50! I don’t think this gas to do with codecs but with formats. Is there anybody out there with the same setup as I? (ingesting P2 footage (1080i) in FCP 6 and exporting this with XML to M100 V14?
    John Twigt
    The Netherlands
  • John Twigt
    August 18, 2009 at 6:57 am
    Now that we can run FCP and M100 on the same disk, as you say, I will install V14 on the same disk and try again.
    I suppose OSX 10.5..8. is suited for the (V14) suite V1?
    John Twigt
    The Netherlands
  • John Twigt
    August 18, 2009 at 7:52 am
    UPDATE :
    I installed V14 on the same startup disk as FCP, so the forementioned 1080p25 clips from FCP can be played in QT-player, so the codec is active.
    When importing XML file M100 says immediately while trying to import the shots “are you sure you want to cancel the media import?” When choosing ‘no’ it just repeats over and over until you hit ‘yes’ and then the imported sequence is offline.
    When I try to import the ingested files (QT flies from the FCP media folder) directly from the finder it gives a program error code -9077. The application now has crashed because all actions will result in a error code of -9077.
    What could be going on here?
    I am seriously handicapped here, because I have a complete project ingested by FCP (including offline edits by another editor) and i am now forced tot stay within FCP. Not really my favourite NLE ….
    John Twigt
    The Netherlands
  • Floh Peters
    August 18, 2009 at 8:53 am
    John, can you zip one of the media files and upload it somewhere, like YouSendIt or an FTP server to have a look at it? Not really sure what is going on here…
  • Wickham Strub
    August 18, 2009 at 2:17 pm
    Hey John,
    When you do get something available to look at, please send the link to support@media100.com with my name, Wick, included in the subject line. My engineers want to take a look at them.
    Wick
  • John Twigt
    August 18, 2009 at 5:45 pm
    Thanks Floh and Wick for your responses.
    I’ve been away from my set since this morning around 11, so just a moment ago I read the posts.
    First thing tomorrow morning I will make a clip available to both of you.
    I’m also very curious what could be going on here.
    John Twigt
    The Netherlands
  • John Twigt
    August 19, 2009 at 2:15 pm
    Did you and Wick receive the file I sent you? Just curious if the Yousendit arrived.
    thanks
    John Twigt
    The Netherlands
  • Wickham Strub
    August 19, 2009 at 2:40 pm
    Got it. Will pass it on to Engineering and see what they think.
