Wickham Strub
August 21, 2009 at 9:43 pmHi John,
Sorry for the delay in getting back to you. The truth is it is because we have been unable to reproduce your problem with the media you send us. (although it DID help us fix another unrelated bug. Thanks!)
So… I’m beginning to think that your troubles are install-related.
I’ll be in touch with you via email about what to try next as, at this point, it’s pretty safe to say that your problems are specific to you and your system.
~Wick
John Twigt
August 30, 2009 at 4:39 pmAn update:
i have been able to solve the problem with errors on opening the XML file in M100. (Had to do with permissions on hard drives). It now opens but starts rendering the files. It interpret the files as SD, so it creates a 1080 (green) screen with in the upperleft corner the SD-sized image from the original file. Quit confusing. All settings are fine (everthing on 1080 etc etc) I tried several exports and imports with different export settings (xml versions and including metadata on/off )
Im ‘ in the middle of a huge project (15 films) so I’m not able to spend a lot of time testing every possibility. Seems that i’m stuck with FCP for now.
WICK: from your answer I understand that you have some options for me to test? Please let me know if you’ve got something, ok?
John Twigt
Workstation BV, Amsterdam
The Netherlands
http://www.workstation.nl -
John Twigt
August 31, 2009 at 9:31 am -
Wickham Strub
August 31, 2009 at 2:35 pmStrange,
I am having no trouble importing the file that you provided for us to to test with (the tracking shot outside the fort — 003805).
However, I DID see the problem you describe (mostly green screen with a small frame of the image in the corner) with an in-house build of M100 while we were working out the problem. Perhaps your install of M100 is in some sort of limbo between v1.0 and 1.0.1?
I’ll run another test and report back soon.
~Wick
Wickham Strub
August 31, 2009 at 3:14 pmOkay, try this…
Copy your file to another drive volume and then import it from there. Simply duplicating the file on the same drive isn’t enough.
Try that and let us know what happens.
~Wick
