Activity Forums Apple Final Cut Pro Legacy DVCPro and Closed Captions
  • DVCPro and Closed Captions
    Posted by Jaranaga on August 6, 2007 at 4:02 pm
    I’m trying to “Print to Video” a 30 min show to a DVCPro tape, but it is not recording the closed captioned. The show is CC, I’m tested it, I’ve looked at the settings for the DVCPro and everything should be in order. Could it be that I it is connected through the firewire cable? could I be loosing the lines where the CC is stored? Any ideas would be welcome…
    Jessica
    PowerMac G5 Dual 2GHz
    OSX 10.4.9
    Final Cut Pro 5.1.4
    Panasonic DVCPro50 model AJ-SD93
    Jaranaga replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
