Activity Forums Apple Final Cut Pro Legacy DVCPRO 50 Speed Effect Problems-Help!
  • DVCPRO 50 Speed Effect Problems-Help!
    Posted by Jhouston on February 15, 2007 at 10:17 pm
    I have footage shot in 24P, anamorphic 16×9 from a Panasonic SDX900 in DVCPRO 50. It was captured as DVCPRO 50 and my sequence is the same speed. Here’s the problem:
    When the footage is 100% normal speed, it plays back just fine. But if I try to put a speed effect on the footage (I’m slowing it down), the picture looks “doubled” and stuttery and generally horrible. I tried many different speeds too, and I have the frame blending checked and constant speed on. All the same result=ugly.
    While trying to resolve this problem, I made a new sequence with DV/DVCPRO NTSC settings and even though it wanted to render the footage, when I did the speed effect and rendered it in this DV/DVCPRO NTSC sequence, it looked perfect. So how do I get my native DVCPRO 50 sequence to look this nice cause something ain’t right.
    Thanks in advance!
    Jeremy Garchow replied 19 years, 7 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    February 15, 2007 at 10:34 pm
    Did you render? FCP is not known for awesome time remapping. Perhaps you should check out Twixtor.
    Jeremy
  • Jhouston
    February 15, 2007 at 10:37 pm
    The DVCPRO 50 sequence doesn’t want to render the speed effect. I tried to force it but it didn’t work/help. However, the DV/DVCPRO NTSC sequence I did render and it looks great. Weird!
  • Jeremy Garchow
    February 15, 2007 at 10:42 pm
    Go to your Sequence > Render All and Sequence > REnder Selection menus and make sure that all of the options are checked, especially ‘full’. Then hit option-r to render all the rt effects.
    Jeremy
