Activity Forums Apple Final Cut Pro Legacy DVCPro 50 deck issues
  • DVCPro 50 deck issues
    Posted by Shaun Lavery on May 1, 2008 at 5:50 pm
    Hello
    I’m having an issue with setting up a DVCPro 50 deck to digitize through final cut. Set the deck up but the viewer only shows jumpy green lines. Have my device preset on DVCPro HD, but it does the same thing on Firewire Basic. My codec is set on Aja Kona 3: 720p 59.94 DVCPro HD. Also, if I try DVCPro50 NTSC it gives a bunch of snow. Anyone got any suggestions?
    Walter Biscardi replied 18 years, 4 months ago 3 Members · 2 Replies
  • Richard Harrington
    May 3, 2008 at 2:53 am
    DV50 is not DVCPRO HD
    match your easy setup to the device
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Walter Biscardi
    May 3, 2008 at 3:30 am
    [Shaun Lavery] “I’m having an issue with setting up a DVCPro 50 deck”
    Which deck?
    [Shaun Lavery] “My codec is set on Aja Kona 3: 720p 59.94 DVCPro HD”
    That’s completely incorrect. DV50 is standard definition. It is not high definition.
    [Shaun Lavery] “Also, if I try DVCPro50 NTSC it gives a bunch of snow. Anyone got any suggestions?”
    You’re not using the correct easy setup.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
