Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO 50 @24P
DVCPRO 50 @24P
Posted by Paul Turlick on September 26, 2005 at 6:22 pmHi-
I’m doing my first project (I hope) with this format. Working within FCP 4.5 what would be my capture/sequence settings to pull this off? Does it matter or is it possible to do with the Aja IO or Kona 2? Forgive my naivete on this one…
TIA-
PaulJeremy Garchow replied 20 years, 12 months ago 3 Members · 3 Replies -
Jeremy Garchow
September 26, 2005 at 6:45 pmThere’s a number of factors to consider and they lie mostly in how the footage is to be shot which will then affect how you capture.
First, is the footage true 4:3, or is it anamorphic 4:3 (aka 16:9). This will affect if you need to click the anamorphic button on sequences and on logged clips.
Second, is the footage shot 24p Normal, or 24p advanced. If it is shot 24p Normal then you capture and edit just as you would any NTSC footage at 29.97 fps. You can also use your K2 or aja io top capture this footage at any codec you please via SDI or analog component.
If the footage is shot 24p Advanced, then you have to capture using firewire into the DV50 codec and remove the advanced pulldown on the fly. CUrrently, I do not know of a capture card that can remove the advanced pulldown on the fly, even though it’d be nice cuz that way you wouldn’t be locked to the dv50 codec, which for all intents and purposes is a nice codec, but can fall apart after a couple of generations. Your capture presets will still be set to 29.97 but you need to have the remove advanced pulldown feature checked. Your sequence presets will be set to 24p.
Hope this helps.
Jeremy
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Julier
September 30, 2005 at 6:31 pmHi there!
I’m about to start editing footage shot on dvcpro50 at 24p anamorphic and I’m not sure what’s the best way to go using final cut pro 5.
If the footage was shot at 24p normal, what are the consequences capturing and editing it at 29.97 via fire wire?
Is it possible? will it still have that 24 p look? will it be fine later on, encoding a dvd?
Thanks!!!!!
Jeremy Garchow
September 30, 2005 at 7:46 pm[julier] “If the footage was shot at 24p normal, what are the consequences capturing and editing it at 29.97 via fire wire?”
Nothing really. you are just confined to the DV50 codec for you edit and graphics. In most cases this codec will work just fine.
[julier] Is it possible? will it still have that 24 p look? will it be fine later on, encoding a dvd?
“It’ll have to 24p look with a 3:2 pulldown. It will look really good. You will be fine encoding to DVD. It’ll be just like making a regular 29.97 DVD, no difference at all.
