Activity Forums Apple Final Cut Pro Legacy DVCAM Deck Problems
  • DVCAM Deck Problems
    Posted by Chris Suchorsky on September 17, 2009 at 11:32 pm
    So I’ve had this Sony DVCAM Deck (DSR-11) for two years and it’s never given me a problem. Well, today it stopped working. I hooked up a new Panasonic HPX170 for import and afterwards the DVCAM deck wouldn’t work on output. I’ve gone through everything I can think of.
    I’ve…
    1. Trashed all preferences
    2. Reset everything to match DV/NTSC
    3. Hooked DVCAM deck up to another computer (doesn’t work)
    4. Hooked up another DV Deck to FCP, it does work
    5. Tried different cable
    6. Zapped the pram
    Now here’s the weird part. If I play a tape in the deck it’s fine. The computer is recognizing the deck in the system profiler. But get this, the deck will not play back from the timeline, but it’ll capture footage. What the heck is that about? I tried it on two separate computers.
    And yes, I reset the deck.
    Any ideas?
    Chris Suchorsky replied 17 years ago 1 Member · 1 Reply
  • Chris Suchorsky
    September 17, 2009 at 11:45 pm
    I fixed it. INPUT SELECT Switch was set to VIDEO as opposed to DV. Must have gotten hit in the shuffle of decks.
