Activity Forums Apple Final Cut Pro Legacy DVC Pro QT from AE plays back rough in FCP
  • DVC Pro QT from AE plays back rough in FCP
    Posted by Joe Procopio on October 10, 2008 at 8:43 pm
    Mac PowerPC 2.8Ghz quad, 4.5GB ram
    DVC Pro QT from AE CS3, sequence settings match file, playback looks as if fields are doubled…nothing we do to the file or sequence helps playback.
    used easy setup, nothing, changed fields nothing, 8 bit 10 bit nothing helps…
    file plays back 100% correct in our AVIDs…
    any suggestions?
    Joe Procopio replied 17 years, 10 months ago 4 Members · 10 Replies
  • 10 Replies
  • Richard Sanchez
    October 11, 2008 at 12:17 am
    DVCPRO HD, DVCPRO 50, or DVCPRO (akin to DV)? If you rendered to DVCPRO HD with a raster of 1280 x 720, you’ll have problems since DVCPRO HD’s native raster is 960 x 720. If it is DVCPRO 720×480 that is strange indeed, being that it plays back correctly in your Avid systems.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Joe Procopio
    October 11, 2008 at 1:37 pm
    i believe it was 1280×1020…that is still strange that it plays back in AVID though. so is there a way in AE to change the aspect without screwing up the relationships of all the graphics in the composition?
    Broadway Video, NYC
    AVID/FCP editor/engineer
  • Joe Procopio
    October 11, 2008 at 1:45 pm
    or, are both aspects true 16×9?
    Broadway Video, NYC
  • Kevin Monahan
    October 11, 2008 at 5:27 pm
    1280 x 1020? Never heard of a frame size like that. Try a standard frame size.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Richard Sanchez
    October 11, 2008 at 11:35 pm
    Since Avid is going to want to work with OMF (or MXF in this case since it’s HD) the first thing Avid does is conform the media to format that it can work with most efficiently. It may not necessarily adjust the aspect ratio so the image may be skewed, but that’s how Avid is going to work with it.
    Since Final Cut doesn’t do this, and since 1280 x 1020 isn’t a standard HD format that FCP will have an Easy Setup for, it’ll place it in the timeline but will require a render to playback. As far as exporting from AE, I’d recommend if you export a DVCPRO HD file, it needs to be 960×720, or you can export a 1280×720 file in ProRes which would work well too.
    Richard Sanchez
    North Hollywood, CA
  • Katherine Burke
    October 13, 2008 at 4:02 pm
    I believe Joe meant to say “1280×1080” which is a standard size and exists in the AE pull-down for DVCPro HD. It also exists as an “easy setup” in FCP. For some reason though, we are having trouble playing it back through Final Cut.
  • Joe Procopio
    October 14, 2008 at 12:20 pm
    yes, 1080…it was late, i was tired….
    Broadway Video, NYC
  • Katherine Burke
    October 14, 2008 at 2:02 pm
    Turned out, we needed to DOWNGRADE our version of “Deck Link” (the controller for the Black magic card.) That did the trick. Weird.
  • Kevin Monahan
    October 14, 2008 at 4:22 pm
    Thanks for posting your solution. Wish more folks would do that.
    Kevin Monahan
  • Joe Procopio
    October 14, 2008 at 5:04 pm
    but this only had to be done in one system…apparently, there is a mismatch of Quicktime, which I will look into, which may have caused an issue as well.
    Broadway Video, NYC
