Activity Forums Adobe After Effects DVC Pro HD frame size in AE?
  • DVC Pro HD frame size in AE?
    Posted by Jordan Montreuil on March 21, 2008 at 11:19 pm
    I have been working with some DVC Pro HD footage in Final Cut and I am working on my workflow from FCP to AE and back.
    The problem I am getting is that my frame size is 1280×720 in the Quicktime movie and in FCP but when I import my footage into After Effects, it brings it in as 960×720. The footage is squashed horizontally and is in a standard format instead of a widescreen format.
    I have tried re-interpreting the footage but nothing good has come out of it. I inspected the movie in QT and have taken a picture of the file information to show you.
    https://www.jordanmontreuil.com/Files/Pictures/Picture%201.png
    I created independent master clips that I am editing with, instead of the captures from the P2 files, and they exported out of FCP at 1280×720 instead of the 960×720. I thought this would change it but After Effects still reads the master clips at the old frame size.
    What am I missing here? I hope someone can help me. Its nearly impossible to work with the footage in AE in its current state.
    Thanks.
    Jordan Montreuil replied 18 years, 1 month ago 2 Members · 4 Replies
  • Steve Roberts
    March 22, 2008 at 7:58 pm
    Why don’t you (in AE) interpret at 960×720, pixel aspect ratio of 1.33?
  • Jordan Montreuil
    March 23, 2008 at 4:57 pm
    It is interpreted at 1.33
    https://www.jordanmontreuil.com/Files/Pictures/Picture%202.png
    It’s still showing at standard screen format. It should be widescreen. Am I doing something wrong?
  • Steve Roberts
    March 23, 2008 at 7:44 pm
    Click the pixel aspect ratio correction switch at the bottom of the comp window.
  • Jordan Montreuil
    March 23, 2008 at 8:54 pm
    Thank you so much for your help. Its the little things that you realize you don’t know that really stop the big things from going forward. I really appreciate your help.
