Activity Forums Panasonic Cameras DVC footage filmed in 16:9 but coming out in 4:3 on HD1200A
  • DVC footage filmed in 16:9 but coming out in 4:3 on HD1200A
    Posted by Jonbfrombc on August 23, 2006 at 7:55 pm
    We recently did a shoot with the DVC tapes in 16:9. However, when we put the tapes in the HD1200A the footage is coming out as 4:3 and is being imported as such in FCP. We’ve tried everything does anyone have any suggestions?
    Jon Beauchamp
    Bud Solem replied 20 years ago 4 Members · 3 Replies
  • Shane Ross
    August 23, 2006 at 8:02 pm
    Do they also happen to be DV quality? That deck can downconvert to DV as you capture. Setting 804 I think, in the 1200HD menus.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Steve Mahrer
    August 23, 2006 at 8:41 pm
    Jon:
    Were the tapes standard def i.e. DV, DVCPRO or even DVCPRO 50? If so, the AJ-HD1200A deck has no means of cropping a “16×9 tape” to a “4×3 OP”…. The 1200 can do that from an HD tape, but not an SD tape. in a nutshell, the deck can’t do that to SD tapes.
    Steve Mahrer (Panasonic Broadcast)
  • Bud Solem
    August 24, 2006 at 6:06 pm
    Can’t you check anamorphic “yes” in the FCP browser for each clip after you import and have FCP recognize them correctly? I haven’t used the HD1200 deck, but have imported from dvcpro tapes shot 16×9 – via firewire and all worked fine.
