Activity Forums Apple Final Cut Pro Legacy DV + XDCAM mixed media timeline – possible? Easy?
  • DV + XDCAM mixed media timeline – possible? Easy?
    Posted by Chris Foogs on June 11, 2009 at 2:14 pm
    Hi all,
    I’m trying to figure out a workflow for a future job. A show is being shot with an XDCAM (unfortunately the coordinator can’t tell me if it’s EX or otherwise, but she says it will be SD). But they will also have some footage to be digitised in during the edit from DVCAM and Digibeta.
    Is there a timeline/easy setup that will playback both the XDCAM footage and DV footage together? They don’t want to conform.
    Would it be possible for the XDCAM files to be imported at DV res, and therefore have a completely DV timeline? Does this add significantly to the import time.
    We aim to have the media stored on our editshare, so data rates will be important too.
    Thanks for any help, I’m totally new to XDCAM.
    All the best,
    Chris.
    John Fishback
    replied 17 years, 3 months ago
    2 Members · 3 Replies
  • John Fishback
    June 11, 2009 at 2:53 pm
    I’d capture/convert all to Prores and edit in that format. Turning a higher quality signal (XDCAM) into DV makes no sense. Also, editing in a DV timeline will make any pix or graphics look terrible.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Chris Foogs
    June 11, 2009 at 3:11 pm
    Hi John,
    many thanks for the response. In order to import the XDCAM files at pro-res, do I use a setting in the sony file transfer utility? Or does it occur elsewhere in the import?
    And do you know what kind of file sizes and bitrates are associated with pro-res – are they comparable to DV or are they much larger? I have to consider the capacity and capability of our editshare.
    Thanks again,
    Chris.
  • John Fishback
    June 11, 2009 at 10:29 pm
    Chris, I’m sorry, but I don’t have direct experience with XDCAM. Checkout this thread https://forums.creativecow.net/thread/8/1037247#1037341 There are probably more you can search out on the Cow.
    As for data rates, ProRes is 5 times that of DV. Here’s a link to a chart of data rates courtesy of Dulce. https://www.dulcesystems.com/html/video_space.html
    John
