Activity Forums Adobe Premiere Pro DV to NTSC Widescreen DVD
  • DV to NTSC Widescreen DVD
    Posted by Mitchell Daniel on June 22, 2008 at 11:59 pm
    Hi I am trying to go from a DV Tape to Record to DVD in widescreen ntsc
    my footage comes in as 720 x 480 I did not recored in on my camera in widescreen. I used a Sony DCR-HC52. Connected firewire to capture. When I import my video just sits in the middle of them screen with black on outside and on bottom. I have tried motion but that makes it look stretched. I tried scale to fit size. Im really not to care to export to dvd im gonna author it myself in Encore but want the final avi to look good. How can I get it to be correct Thanks
    Heres what I see
    Vince Becquiot replied 18 years, 2 months ago 2 Members · 3 Replies
  • Vince Becquiot
    June 23, 2008 at 4:37 am
    You first must import it into a wide screen project.
    Either it will look stretched (horizontal scale only) or you will have to zoom in to fill the sides, cropping top and/or bottom (losing resolution). The second option may also require some keyframed tilting throughout the footage.
  • Mitchell Daniel
    June 23, 2008 at 4:45 am
    i have imported it into a wide screen project did you see the image? so its either a loss of resolution or stretched ?
  • Vince Becquiot
    June 23, 2008 at 4:51 am
    I couldn’t open the url even after adding the ://, but, yes unfortunately, it’s either stretched or zoomed in.
    Vince
