Activity Forums Apple Final Cut Pro Legacy DV to Flash FCP workflow
  • DV to Flash FCP workflow
    Posted by Andrew Roger on May 5, 2008 at 3:15 pm
    I originally pasted a laboriously long post in FCP Basics forum here
    Basically, I have a DVX-200 shooting 480p and a GL2 shooting 480i with intent for flash video for the web. I was taught to do everything in DV NTSC (capture, sequence, & export). Additionally I am adding After Effects projects, Illustrator and Photoshop files, and Livetype and Motion projects into the mix. I used Flash Encoder to do the de-interlacing.
    But now what I would like to do is shoot, capture, sequence, and export with progressive in mind. So what I want to know is what kinds of capture presets and sequence and export settings should I use for our Web only content.
    Andrew Roger replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
