Activity Forums VEGAS Pro DV tape: Lower Field First? Interleave every 0.250 seconds? (Rendering clips at original quality)
  • DV tape: Lower Field First? Interleave every 0.250 seconds? (Rendering clips at original quality)
    Posted by Jill Simpson on February 4, 2009 at 4:37 pm
    By searching I have found that all the video and audio settings for the pre-defined NTSC DV template are equal to the format on a mini-DV tape…. except “Field Order: Lower Field First” and “Interleave every 0.250 seconds”. Those may be intrinsic to DV format, but I have not been able to verify that.
    I want to render some unprocessed/unedited clips – we captured some whole tapes, selected keeper clips, and I now want to render those in the same quality as if we had logged and captured only those clips.
    If I render my clips using the Lower Field First setting, will that create a problem if in a future project I want to use the “None” or Upper Field First setting?
    Interleave: every 0.250 seconds?
    Thank you.
    John Rofrano replied 17 years, 7 months ago 2 Members · 1 Reply
