Activity Forums AJA Video Systems DV playbakc with KONA LH all messed up…
  • DV playbakc with KONA LH all messed up…
    Posted by Mattso on October 18, 2005 at 10:19 pm
    I am trying to playback DV material and have it playback through the LH card we just installed, but it isn’t working. I get a PIP sort of thing, with a quarter-screen sized window playing in the upper right hand corner of my NTSC monitor, playing over a full-sized still frame of Frame #1 of the clip. I’ve tried every SD output, and toggled everything I can find… to no avail. If I render the timeline in 10-bit, it will play fine, but I have to ask, doesn’t DV play out of this card?
    thanks.
    matt,so
    Walter Biscardi replied 20 years, 10 months ago 2 Members · 1 Reply
  • Walter Biscardi
    October 19, 2005 at 1:06 pm
    Are you working in a DV timeline? You should use the Easy Setup for DV-NTSC (or PAL depending on where you are) and then simply change the Video Playback to the LH using the 8bit NTSC (or PAL) setting.
    Walter Biscardi, Jr.
    Now editing “Good Eats” in HD for the Food Network
