Activity Forums Blackmagic Design DV PAL – reversed field-order
  • DV PAL – reversed field-order
    Posted by Christian Schaefer on April 19, 2011 at 2:16 pm
    Hello,
    I use a “Intensity pro” to playout The After Effects (CS4) Timeline…
    My Project is Standard PAL (720×576 interlace)…
    If I import a normal DV-PAL-Clip (captured through Firewire) and play it out, the field order is reversed!
    I have done some Tests and play-out the DV-Clip (PAL) in After Effects through a Firewire-Device (Camcorder with DV-In)
    => The Fields are shown correctly!
    If I play out the same Test-Clip through “Blackmagic Video Output” the Fields are reversed!
    That means if I use “BM-Video Out” the Field-Order is reversed, but this happens only with DV-Clips not with Clips captured with Blackmagic-Codec!
    What can I do?
    Wolf replied 15 years, 4 months ago 2 Members · 2 Replies
  • Christian Schaefer
    April 21, 2011 at 10:13 am
    Someone else have this problem???
  • Wolf
    May 1, 2011 at 8:33 am
    Hi christian,
    i have the same probleme with dv since years and years.
    Wrote many time to bm and this forum, but never get a
    faluable answer.
    I hoped with every new driver, that i would be solved.
    But after years i gaved up.
    Now, when i have DV-material i digitalize it
    with a DVCam deck with SDI out.
    I know, it don´t help you, but i can tell you,
    you are not alone 😉
    Greating from Cologne
    claus-Peter
