Activity › Forums › Apple Final Cut Pro Legacy › DV Pal into a P2 timeline
  • DV Pal into a P2 timeline
    Posted by Neil Sinclair on June 22, 2007 at 7:09 am
    I need to drop in DV (720×576)footage into my P2 timeline (960X720). Would appreciate advice as to the best way to scale the DV. Is it preferable to scale in FCP or to batch export the DV clips at 960×720
    and reimport. Any advice appreciated.
    Neil Sinclair replied 19 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    June 22, 2007 at 7:15 am
    If you are using FCP6 then you can drop the DV into the timeline and FCP should automatically scale it to your sequence setting. Make sure you have the anamorphic flag ticked if the DV footage is 16:9.
    If you drop it in a FCP 5 timeline and manually scale it will need to render and any changes like color grading will require a re-render.
  • Neil Sinclair
    June 23, 2007 at 3:24 pm
    Thanks for the advice
    Regards
