Activity Forums Apple Final Cut Pro Legacy DV footage into HDV980x720
  • DV footage into HDV980x720
    Posted by Okisada Okisada on July 26, 2007 at 7:02 pm
    I am trying to apply DV 720×480 footage to HD 980×720 sequence to create some space under the pic to add some subtitles.
    This is just an experiment I am doing, but should I match the field dominance of the DV clips to HD sequence(Upper) to get the successful looks on DVD? Or should I set the sequence setting to None so that I can have it as the same as the clips themselves? Or should I even worry about the field issue?
    Eventually i am gonna make SD DVD with the project though.
    Can you give me some advices please?
    Keiko
    Okisada Okisada replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
