Activity › Forums › Apple Final Cut Pro Legacy › DV firewire capture looks horrible
  • DV firewire capture looks horrible
    Posted by David Soriano on November 16, 2010 at 6:39 pm
    i am running FCP 7.03 and, for the first time, captured some DV footage shot on PD-170. The playback quality in FCP viewer/canvas is horrible. Of course there’s the interlacing, which is to be expected, but the resolution is bad. Soft, uber-compressed footage is all i see. Nothing like what i get when editing same DV-type footage on Leitch Velocity 8. Of course there i can set compression rate, which i normally have set at 5-7Mb/sec. Here, in FCP, we are locked in to 3.6, right? Anyway, with the DV preset that gives 3.6 i am getting horrible results. It’s like worse that S-VHS, down there with VHS quality. Will it look better once output to DVD/.mov file, or am i looking at what i am going to get? Also, is there a way to change the 3.6 Mb/sec data rate to something higher, or am i stuck with this preset?
    What gives, am i doing something wrong?
    thanks for any help.
    David Soriano replied 15 years, 10 months ago 3 Members · 5 Replies
  • David Roth weiss
    November 16, 2010 at 6:46 pm
    I’ll bet you a zillion dollars that your canvas size is not set to exactly 100%. Wanna bet???
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • David Soriano
    November 16, 2010 at 6:59 pm
    it helped, a bit. Have i been looking at HD footage (EX-1) for so long that i forgot how DV looked? Is 3.6 standard rate for DV? That’s kinda low, no? Is there no way to customize the capture rate?
  • David Roth weiss
    November 16, 2010 at 7:04 pm
    You can pay with a check or with Paypal…
    DV is set in stone. You are capturing the digital information as stored on tape, it’s not a reduced bitrate.
    David Roth Weiss
    Los Angeles
  • Rafael Amador
    November 16, 2010 at 7:19 pm
    [david soriano] ” Nothing like what i get when editing same DV-type footage on Leitch Velocity 8. Of course there i can set compression rate, which i normally have set at 5-7Mb/sec”
    That sounds to DV50.
    rafael
    http://www.nagavideo.com
  • David Soriano
    November 16, 2010 at 9:15 pm
    that’s right…i knew that. With Velocity i never captured via firewire, only component using a DV deck, so i could set bit rate.
