Activity › Forums › Apple Final Cut Pro Legacy › DV FIELS ISSUE when convert to 10bit Uncompressed
Rafael Amador replied 17 years, 10 months ago 5 Members · 11 Replies
Rafael Amador
November 27, 2008 at 3:49 pmHi Vincent,
[Vincent Manuhuwa] “Quicktime (when set to High Quality) shows the interlace lines even when the field order is correct. So seeing a comb effect is not a bad thing, as quicktime just shows you the fields.”
This is an interesting observation. I agree, seeing the combs it doesn’t necessarily means field order problems. The field order problems are easy to detect in pictures with movement.[Vincent Manuhuwa] “Take a bit on the time line, and reduce speed to 50%”
I don’t know if this will helps to see anything clear.
Shift Fields + Sepeed Changes with Frame blending is a NO-NO.
I’ve just past through this again this week. You need to nest the clip with the filter, then apply the Speed Change, otherwise the whole house shakes.
Rafael
