Activity Forums Adobe Premiere Pro DV Device Problems
  • DV Device Problems
    Posted by Terry Hahin on June 14, 2006 at 7:55 pm
    Hello,
    I am having a terrible time with controlling DV Devices with Adobe Premeire. I’m Using Ver 1.0, and operating on a single processor 2.8 Ghz and running the application with a 10,000 rpm hard drive. As far as I can tell I should have no problem capturing or playing back DV res material.
    Once in a while the device will operate properly, but after a batch capture or switching tapes or anything it seems the camera will simply go offline and not work until what seems to be a random combination of restarts of the application, computer, or the camera. It is a Canon ZR20, which has always worked fine under the Canon “Standard” setting under DV Devices in the past.
    Not only do I have dropped frames about every 3 minutes, but then the device is constantly going randomly offline. I tried switching Firewire cables, and it worked for about an hour and then stopped working again. I tried all of Adobe’s recommendations of alternateing DV Devices settings, Capture/playback settings, etc.
    Does anyone have any thoughts or similar problems. This is costing me a lot of money with clients.
    Thanks in advance.
    Terry
    Vince Becquiot replied 20 years, 2 months ago 2 Members · 1 Reply
  • Vince Becquiot
    June 14, 2006 at 11:18 pm
    That problem is usually due to fragmentaion on the disk, or issues with disk transfer speed. Your sytstem seems way ahead of minimum requirements though.
    You could try downloading a program called Windv: https://windv.mourek.cz/.
    That should take care of your dropped frames issues (Uses a memory buffer), and hopefully the random restarts as well.
    Cheers,
    Vince
