Activity › Forums › Adobe Premiere Pro › DV Capture – what’s the best set up for me?
  • DV Capture – what’s the best set up for me?
    Posted by Elizabeth Jarosz on August 3, 2008 at 1:44 am
    I’ve been capturing and storing straight into my laptop hard drive. I’m getting a bunch of dropped frames and I’m wondering if it’s because of this.
    I have an external hard drive (GTech G Raid), but can’t figure out how to configure all the wires to use it to capture straight to it. I’m hoping one of you can help.
    I think the best thing is to hook the GTech External drive to my computer and then the camera to the GTech drive, right? The only thing is I can’t seem to see how that will work.
    – My computer has ONE Firewire port (400).
    – GTech has three Firewire ports (1 400, and 2 800) + USB 2.0
    – My camera has one Firewire port 400
    I’m assuming the 800 Firewire ports are useless in this scenario.
    Right now I have the GTech 400 going into my computer 400. Then I have the camera 400 with no where to go. Do they make a chort for Firewire 400 to USB 2.0? If so, would this work???
    Help 🙂
    Elizabeth
    Vince Becquiot replied 18 years, 1 month ago 2 Members · 1 Reply
  • Vince Becquiot
    August 3, 2008 at 3:19 am
    Nope, you can’t really put 2 devices on the same firewire port, that’s probably the cause of your dropped frames.
    It could also be the laptop, specs please.
    What I would do is purchase a PCMCIA or express card (depends on what your laptop has) that has either a Firewire 400, or even 800.
    You could also capture directly to the laptop. If it’s DV, you can buy a 300 GB drive; that should give you enough space to capture then move to the G-RAID.
    You could even put the G-RAID on USB, that would still be better than sharing the port with the camera.
    Vince
