Activity Forums VEGAS Pro DV Capture File Naming in HD Platinum 10
  • DV Capture File Naming in HD Platinum 10
    Posted by Tony Cerqua on August 26, 2010 at 7:28 am
    Does anyone know if there is a way of getting Vegas to name the clips that it captures from an (SD) DV tape according to the date/time the footage was shot?
    For example if you use WinDV to capture (supports SD only) it will automatically append the date and time of the actual clip to the clip filename eg HoneyMoon_2004_08_13.09_54_15.avi Unfortunately Vegas seems to just number the clips sequentially, eg Clip 1.avi, Clip 2.avi ….
    Many thanks
    Tony
    John Rofrano replied 16 years ago 2 Members · 3 Replies
  • John Rofrano
    August 26, 2010 at 2:25 pm
    No, there is no way. Vegas SD capture just starts with the name you choose and appends a numeric suffix.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tony Cerqua
    August 27, 2010 at 12:33 pm
    many thanks john, decided to just stick with WinDV which seems to be working ok on Win 7. I realised that the only thing that was “annoying” WinDV in the first place was the EPU-4 software running on my PC (Asus mobo) that was switching the monitor off after 20 minutes for power save. As it turned out this power saving was also causing Vegas to foul up too.
    Thanks again
    Tony
  • John Rofrano
    August 27, 2010 at 1:08 pm
    Wow, that’s really good to know. Long ago (in the days of Windows 98) I had installed some still camera software that had a component that stayed resident and every once in a while it would poll the USB drives to see if you inserted a card. Every time it woke up, I would drop frames during capture. It drove me crazy until I found out what it was. That’s why it’s important to keep minimal software on a video editing PC.
    ~jr
