Activity Forums Apple Final Cut Pro Legacy DV and HD frame sizes
  • DV and HD frame sizes
    Posted by Dcj1900 on November 29, 2005 at 4:02 pm
    We use FCP versions 4.5 and 5 as offline edits for high definition product. We digitise in at DV resolution from a variety of HD sources through Kona LS cards. Sadly, since DV has a native frame size of 720 x 576, and HD has a frame size of 1920 x 1080 any camera moves that are created in the offline have to be recreated in the online – using up valuable online time. Does anyone know of a compression codec that allows native 16:9 (non anamorphic) capture so that the 16:9 coordinates can transfer from the offline to the online? Or does anyone have a clever solution?!
    Thanks.
    Dcj1900 replied 20 years, 10 months ago 2 Members · 2 Replies
  • Joseph Bradley
    November 29, 2005 at 8:34 pm
    why would you digi at DV res when you’re capturing HD? It’s pretty easy to down res if you need to but working in a DV resolution takes away the look you want for HD.
  • Dcj1900
    November 30, 2005 at 9:58 am
    Thanks for the response. We dig at DV resolution because we use Final Cut as an offline tool to cut the editorial content of the programme – once that is complete we go in to ‘online’ and conform in to FCP just the final edited sequence at HD resolution. Since the average shooting ratio is approximately 25-30 to 1 it is not practical to capture all the rushes at HD resolution as it will eat up our storage resources.
