Activity › Forums › Adobe Premiere Pro › DV 24 frame export bug
Posted by Chris Borjis on February 7, 2013 at 6:08 pmposted this in the media encoder forum but no responses.
Has anyone noticed AME will export a DV 23.976 preset
as 29.97 only?anyone know a workaround to fix this?
sometimes we need DV 24P to be just that.
John-michael Seng-wheeler replied 13 years, 7 months ago 4 Members · 9 Replies -
Tero Ahlfors
February 8, 2013 at 10:18 amAs far as I know the DV specced 24P is actually 23,976.
https://www.adamwilt.com/24p/index.html#24pRecording
Ann Bens
February 8, 2013 at 1:59 pmI am in pal-land so i never do 24p, but i did a little test and yes Mediainfo reads 29,97.
If you set the codec to none, but i do not know if that is what you are looking for the export reads 23.976.———————————————–
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Chris Borjis
February 8, 2013 at 6:48 pmThanks Tero, I am fully aware of that.
The point is Adobe Media Encoder cannote encode
to a DV 23.976 format which is often used
in ProTools for picture reference. -
Tero Ahlfors
February 8, 2013 at 7:00 pmHmm. I have a 23,976 DV option in AME CS6. Are you missing the whole preset/codec?
Ann Bens
February 8, 2013 at 8:00 pmDo an export and run it through Mediainfo.
Chris Borjis
February 8, 2013 at 9:50 pmI have the preset.
I have checked media info – it reports 29.97
Spent lots of time trying to solve it.
AME is encoding to 29.97 even though I set it for 23.976 preset.
MAC version by the way.
It wouldn’t surprise me if not many people use that preset which
might be why hardly anyone has noticed.To get work done, I’ve been reverting to Apple Compressor,
but I prefer to use AME as much as possible. -
February 9, 2013 at 10:28 pmAs far as I know, DV doesn’t technically support frame-rates other then 50i and 60i
If someone here has the ability to check, it would be interesting to see what exactly is in the 23.976 DV files that AME and Compressor are producing. The diference may just be in the metadata. I don’t have compressor so I can’t dig into this.
Chris Borjis
February 11, 2013 at 5:29 pm[John-Michael Seng-Wheeler] “As far as I know, DV doesn’t technically support frame-rates other then 50i and 60i”
DV does support 23.976, though which method I’m not sure.
If I encode it with apple compressor, then open it in quicktime
and do get info it says 23.98Everything coming out of AME is 29.97
When I get quicktime movies at 23.98 for sweetening in protools
ame cannot be used. -
February 12, 2013 at 3:13 amI would love to get my hands on a 23.976 DV clip made by compressor. Just 10 frames would be enough.
JM
