Activity › Forums › Adobe After Effects › Duplicating layers with an automatic offset for each copy…
  • Duplicating layers with an automatic offset for each copy…
    Posted by Sebastian Melmott on December 14, 2010 at 1:09 pm
    Isn’t there a smart way to copy an existing layer eg… 24 times giving each layer an offset in time of, say… 3 seconds without copying (CTRL+D) then dragging each layer along the timeline …?
    Moooooooo….!
    John Cuevas replied 15 years, 9 months ago 3 Members · 2 Replies
  • Kevin Camp
    December 14, 2010 at 5:19 pm
    keyframe assistant will sequence layers and has an option for ‘overlap’..
    that’s a bit different than offset, in that the if your layers were 30sec long and you wanted a 3sec offset, you’d set the overlap to 27sec.
    the other problem could be that your layers are shorter than 3sec, then overlap would not work.
    you might also search for a script that would do this: aenhancers.com, aescritps.com and/or crgreen.com/aescripts/ would be good places to look.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Cuevas
    December 14, 2010 at 9:23 pm
    Pretty sure you have to keep pressing “cntl-d”, but head over to videocopilot.net. In one of the tutorials he created a script that does exactly what you want, he calls it the “sequencer”(Tutorial 103 has it), very handy.
    Johnny Cuevas, Editor
