Activity › Forums › DaVinci Resolve › Duplicating a clip causes their grades to be synced
  • Duplicating a clip causes their grades to be synced
    Posted by Mike Jenkins on July 30, 2014 at 9:28 pm
    Hi forum,
    I am trying to duplicate a clip in the timeline so I can apply two different grades and blend them. I noticed that when comparing two grades with a reference wipe, using the “Mix” function gave me exactly the look I wanted, which was different from either of the two grades. So I figured I could duplicate the clip, apply “Warm” to one clip and “Cool” to the other, then play around with blend modes and opacity until I got the right look.
    HOWEVER…I have a weird problem. After duplicating the clip in the timeline, I stacked it on top of the original. Then I go into the Color room. I have grade “Warm” and grade “Cool” saved, so I open the original and apply “Cool” then go to the duplicate and apply “Warm”. What happens is any time I make a change to one clip, the other is perfectly synchronized (and I don’t want it to be.) So if I apply “Warm” to the original, then apply “Cool” to the duplicate, the original also becomes “Cool”. If I disable a node in one clip, it disables the same node in the other clip. And so on.
    Does anyone know if this is expected behavior, or is this a bug in DaVinci 11 Beta 2? I really don’t want it to operate this way, so if someone knows how to unlink the two clips so I can grade them differently I need to know the right way to do it!
    Thanks in advance.
    Marc Wielage replied 12 years, 2 months ago 3 Members · 6 Replies
  • Eric Johnson
    July 30, 2014 at 10:50 pm
    If you look in the manual RE: remote/local grades, I believe you will find your answer.
    Also, look into parallel/layer nodes and the key mixer, pretty sure you can do what you’re trying to do in one node tree.
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mike Jenkins
    July 31, 2014 at 4:30 pm
    Great thank you! I’ll read up on that now.
  • Eric Johnson
    July 31, 2014 at 5:43 pm
    Upon second reading… also look into “unmix”
    eric b johnson
  • Mike Jenkins
    July 31, 2014 at 9:30 pm
    Thanks for the advice. I’ve been reading the manual on set all day and I think I will get the effect I’m looking for using the Parallel mixer and leaving that at its default setting. Alternatively I will try layer mixing using different composite modes.
    I did a quick search for “unmix DaVinci Resolve” and I can only find references to unmixing dissolve transitions to grade both sides of the effect. Is that what you’re referring to or something else?
  • Eric Johnson
    July 31, 2014 at 9:45 pm
    That’s the one. It also allows you to see what you are selecting if it’s not the top visible track.
    eric b johnson
  • Marc Wielage
    August 3, 2014 at 6:02 am
    [Mike Jenkins] “I am trying to duplicate a clip in the timeline so I can apply two different grades and blend them. I noticed that when comparing two grades with a reference wipe, using the “Mix” function gave me exactly the look I wanted, which was different from either of the two grades. So I figured I could duplicate the clip, apply “Warm” to one clip and “Cool” to the other, then play around with blend modes and opacity until I got the right look.”
    I think you’re trying to do something in a needlessly complicated way. I bet that the exact look you want could be achieved without mixing the two looks together, merely by starting from scratch in a single node.
    Often the trick in color correction is coming up with the right look in the shortest amount of time — not spending precious minutes working and working and working on a look by adding and subtracting corrections. I agree with Eric above that sometimes, parallel nodes can yield some unusual effects by combining simultaneous corrections. The key mixer can also be of help in some cases.
