Activity Forums Maxon Cinema 4D Duplicate TP setup
  • Duplicate TP setup
    Posted by Stephen Turcotte on November 12, 2012 at 4:40 pm
    I have a TP Xpresso setup where particles are born/ emit from a sphere and upon impact with an object activate the birth of another sphere (see attached video). I’d like to duplicate this setup probably 20 times and manipulate the Xpresso settings for each in order for the particles to hit where I need them to. So far I’ve only been able to do this manually by creating new particle groups and reconnecting them in my Xpresso setup, but I’m looking for a more efficient way. Does anyone have any ideas?
    TP world
    Stephen Turcotte replied 13 years, 9 months ago 2 Members · 4 Replies
  • Brian Jones
    November 13, 2012 at 3:41 pm
    Without knowing your set up – are more than one paths coming from each new sphere? – either way, adjusting the emit speed and direction to get them to land where they need to, it seems like it would be a lot easier to just put in your own splines (with the fewest possible points probably set to b-spline) rather than adjust a lot of expresso by trial and error. Unless your needs are something that makes that make more sense.
  • Stephen Turcotte
    November 13, 2012 at 6:57 pm
    Hi Brian,
    Each new sphere does have a different number of paths emitting from the center. They only need to land in a general area, nothing too exact. Maybe animating along a spline would be a bit quicker rather than trying to find a work around. I guess my question is whether it is possible to create one Xpresso setup, like I have, and retain the ability to duplicate it without affecting the original. Every time i duplicate the original rig, the parameters seem to be thrown off.
  • Brian Jones
    November 13, 2012 at 7:01 pm
    if it’s not an exact placement that’s not too bad. Can you post the scene?
  • Stephen Turcotte
    November 13, 2012 at 8:24 pm
    Here’s the scene file with my setup.
    4962_worldmaptest.c4d.zip
