Activity › Forums › Adobe After Effects › Duplicate text with expresion
  • Duplicate text with expresion
    Posted by Brian Scott on May 30, 2008 at 9:13 pm
    I’m trying to get a second text layer to update when the primary one is changed. It works OK, until I make a tracking or kerning change. These don’t ripple through to the other layer. Anyone have any ideas?
    Brian Scott
    President
    Image Design Productions, Inc.
    Kevin Camp replied 18 years, 4 months ago 2 Members · 3 Replies
  • Kevin Camp
    May 30, 2008 at 10:55 pm
    i don’t believe that anything the character palette is accessible from expressions. you may be able to find a script that can do it, but i don’t know.
    a way to make it work is to precomp the text layer (leave all attributes), then use other instances of that text precomp as needed. then as you make changes to the kerning, leading, font, etc. it will update to all the instances…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Brian Scott
    May 31, 2008 at 1:55 am
    I’m actually trying to get the second layer to be a different color and opacity from the first. I’m using a mask to transition the “darker” layer in to emphasize the text as the script is read. I’m sure pre-comping would work for this.
    Brian Scott
    President
  • Kevin Camp
    May 31, 2008 at 3:10 pm
    it sounds like precomping should work, if you precomp the masked layer (leave all attributes) taht should keep all you masked data. then you can drag the text precomp in again to replace the other text layer. then there are several color adjustment layers that you could use to change the color, on of the most basic is just the fill effect, just pick a color to change the text to….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
